Lower life style?
Lower life style?
Postby v8coupe » Wed Jun 11, 2014 4:37 pm
Ok I know this is going to be a little different then most, but I want to lower my D350.
It's a 2wd Dually and I use it to tow so it still must be able to take a large load. Has anybody lowered there D series?
v8coupe
Re: Lower life style?
Postby oldestof11 » Wed Jun 11, 2014 5:06 pm
Have Facebook? If so, look up the 1972-1993 Dodge Truck group. They have a lot of good ideas.
From what I gather, a D150 drop spindle with a pre-85 3/4T wheel bearings will swap into our trucks. Or just do what most do and that's use air bags.
Postby DodgeFreak » Wed Jun 11, 2014 6:12 pm
v8coupe wrote:must be able to take a large load.
I heard from Pete that Levi's good at that...... :lol:
Postby Tacoclaw » Wed Jun 11, 2014 7:37 pm
Oh, come on. :yuck: :lol:
Don't people swap to van LCAs to drop these trucks?
Postby DodgeFreak » Wed Jun 11, 2014 8:35 pm
I just read someplace someone used dakota lowering spindles.
Postby dazedandconfused » Thu Jun 12, 2014 3:11 am
The van lower control arms are used on the light D250 and D150 because they have a pocketed spring mount where the others are flat. Since ours are already pocketed you will see no drop. The drop spindle a I don't have much info on still researching. You can flip the rear axle for a 4"+ drop in the rear and use shorter could in the front. If you are wanting yo go crazy C-notch it and put it on air with drop spindles, pie cut uppers, reverse pie cut lowers.
Postby oldestof11 » Thu Jun 12, 2014 5:06 am
Pie cut?
Postby dazedandconfused » Thu Jun 12, 2014 5:32 am
Yeah you cut a small triangle out of steel then cut the side metal in the control arm out by where the ball joint goes. Heat it up and bend the ball joint area down and weld the triangle in to help ball joint angles. The lowers you cut a small triangle out of the control arms and Ben it down until they touch and weld it solid.
Postby DodgeFreak » Thu Jun 12, 2014 5:39 am
Pics?
Postby v8coupe » Sat Jun 14, 2014 6:28 pm
Are the K members on these trucks welded to the chassis?
v8coupe
Postby dazedandconfused » Sun Jun 15, 2014 5:08 am
They are riveted if I'm remembering right.
Postby v8coupe » Sun Jun 15, 2014 1:15 pm
dazedandconfused wrote:They are riveted if I'm remembering right.
So in theory you could pull it and replace it with a new tubular unit to relocate it.
v8coupe
