4" lift on 33's
4" lift on 33's
Postby Dan NJ » Fri Sep 12, 2014 9:23 pm
Can anyone post some pics of your truck if you are 4" on 33's I'd appreciate it , thank you
Dan NJ
Re: 4" lift on 33's
Postby oldestof11 » Sat Sep 13, 2014 9:20 am
Stock and 33x12.5
Re: 4" lift on 33's
Postby lz69 » Sat Sep 13, 2014 10:36 am
I'll take some pics of mine this weekend and post them for you.
lz69
Re: 4" lift on 33's
Postby Dan NJ » Sat Sep 13, 2014 12:44 pm
Thanks guys
Dan NJ
Re: 4" lift on 33's
Postby Tacoclaw » Sat Sep 13, 2014 7:23 pm
Stock height with 34.5". Worn, they are probably an actual 33" tall.
3" lift with 34.5"
Re: 4" lift on 33's
Postby DMan1198 » Sat Sep 13, 2014 8:33 pm
Here's mine with a 4" lift and 31.5's on the front, and 34.5's on the back
Re: 4" lift on 33's
Postby lz69 » Tue Sep 16, 2014 7:24 pm
Here's a few pics for you 285/75/r16's(32.8") and 4" lift springs.
lz69
Re: 4" lift on 33's
Postby Dan NJ » Wed Sep 17, 2014 7:48 am
lz69 wrote:Here's a few pics for you 285/75/r16's(32.8") and 4" lift springs.
Thanks man, are those weld wheels or imitations?
Dan NJ
Re: 4" lift on 33's
Postby CumminsPower59 » Wed Sep 17, 2014 2:16 pm
Dan NJ wrote: are those weld wheels or imitations?
Most likely Eagles. I had the exact same set, same with Jon.
Re: 4" lift on 33's
Postby oldestof11 » Wed Sep 17, 2014 3:36 pm
What he said. My old truck, which looked EXACTLY like lz69's truck, had 16.5". My new truck are seires 137 IIRC.
Re: 4" lift on 33's
Postby Sutter1stgen » Tue Sep 23, 2014 7:41 am
315/16s (35") with a 6" rough country. I find their lifts to be more close to a 4", friend of mines truck has a 4" super lift, and I was a 1/4" taller all around. Another thing to remember is the difference in 6" and 8" frames will make a big difference in tire rub. I have a non inter cooled 6" frame.
Eric
Sutter1stgen
Re: 4" lift on 33's
Postby CumminsPower59 » Sat Oct 04, 2014 10:04 am
Fine lookin truck right there ^^^ ;)
Re: 4" lift on 33's
Postby Sutter1stgen » Sun Oct 05, 2014 8:51 pm
Thank you. That was spring of 08' and it was fresh out of the both 2 months prior.
I saw a pic of yours floating around, and I must say it's clean ride as well.
Eric
Sutter1stgen
