Brake proportioning valve
Postby MMeier » Wed Oct 22, 2014 11:34 pm
Any idea where to get one nowadays ... outside of another truck ?
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Re: Brake proportioning valve
Postby thrashingcows » Thu Oct 23, 2014 11:01 pm
On a W250 truck it doesn't really have a proportioning valve. Are you making reference to the aluminum junction block just off the MC?
thrashingcows
Postby MMeier » Fri Oct 24, 2014 12:17 am
thrashingcows wrote:On a W250 truck it doesn't really have a proportioning valve. Are you making reference to the aluminum junction block just off the MC?
Yes I am .
MMeier
Postby Tacoclaw » Fri Oct 24, 2014 3:32 am
W250's do have a prop valve, it's a giant, cast iron thing tucked down inside the driver's framerail. Never seen an aftermarket replacment though.
They say if you hit your brakes and a little tit sticks out the end of it, it's functioning correctly and probably not your problem.
I recently put an inline adjuster to my rear brakes (Summit Racing SUM-G3905)and have my fronts hosed direct to the MC, stops damn good. For my RC I bought a full system setup similar to stock(Wilwood 260-11179), but still adjustable. Hope to try it out sooner than later. The Sodge is still drums in the rear, RC is disc.
Postby CumminsPower59 » Fri Oct 24, 2014 6:06 am
NON-IC trucks have it on the frame, the IC trucks have it located by the master cylinder. That tit looking thing is actually a switch, as the valve assembly/piston in the body moves back and forth as the brakes are applied and released. When there is a loss of brake pressure, the piston will move enough to trip the switch, turning the brake warning light on.
If I had to replace mine, I'd do as Tacoclaw did and run the rear on an adjustable unit, so you can fine tune the brakes to how you like ;)
Postby MMeier » Fri Oct 24, 2014 10:48 pm
Found one at a dealer in the bay area, should be here Monday, hopefully that cures it so I can start driving it again after 5 long months and show off the fancy schmancy new paint job !
MMeier
