2wd pickup with 285 75 16 tires
Postby cummins1992 » Wed Oct 29, 2014 8:21 pm
How big of tires will fit on a D250? I have a set of 285 75 16 tires I got for nothing and they have more tread than the 265 75 16 tires that are on my pickup right now. Do you think those will fit on my 2wd rig?
cummins1992
Re: 2wd pickup with 285 75 16 tires
Postby LandTug2 » Sun Dec 21, 2014 12:30 am
I have 265/75/16's on my truck. I have moog heavy duty springs up front and they level it out a bit. With the springs the front tires rubbed a bit on the fender flares while turning. I wound up shaving about an inch off the inner corners of the flares and have had no problems since. I think 285s might work if you take the flares off or cut them back alot further.
'93 D250 5x16s, Stg1 pin, 3200 gov spg, stiffer afc spring, pump tuning, Super Harmonic Damper, Timing Spacer, hx35/ht3b compounds, 100 gpm lift pump, 12" Cone filter, Moog Springs, pyro/drive pressure/boost/f. pressure/tach gauges,valet switch, 4'' straight pipe, mag hitec dif cover
LandTug2
Postby u2slow » Sun Dec 21, 2014 1:19 am
I like to put 285s on the back of my 2wds :mrgreen:
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
