NP205 Mounting Studs
Postby bgilbert » Sun Nov 09, 2014 8:01 pm
Anyone know a source for the fine thread x coarse thread tcase to tranny mounting studs? I'm sure NAPA has something close, but I figured I'd ask here first in case they are special or 'dodge different'. Do they need to have that short unthreaded portion at the tip on the fine thread side?
Bill Gilbert
bgilbert
Re: NP205 Mounting Studs
Postby simplysmn » Sat Nov 15, 2014 8:40 pm
Bill I would think if you could find a stud with everything minus the tip you would be Fine .
simplysmn
Postby Tacoclaw » Sat Nov 15, 2014 9:40 pm
I would imagine you could use a stud with consistent thread and use different nuts as well if it came down to it.
Postby bgilbert » Sun Nov 16, 2014 8:57 am
I haven't taken an old one into NAPA or Oreilly yet. I was really hoping ebay or someone online offered a direct replacement :( .
Bill Gilbert
bgilbert
Postby lz69 » Sun Nov 16, 2014 1:59 pm
Posted a few links earlier but looks like they switched to a metric stud in the late 80's, 04505365 is the Chrysler part number and it should be easy to get at a dealer since they were used to 2011 in other applications.
http://www.factorychryslerparts.com/products/DODGE/REGULAR-CAB-PICK-UP/STUD-Tranmission-Case-M10x154x36/4258082/04505365.html
lz69
Postby bgilbert » Sat Dec 20, 2014 7:21 pm
Well I ordered part number 04505365 and the accompanying fancy washer/nut/locknut. I can post the part number for the nuts if anyone wants it. Turns out the front adapter/bowl I have doesn't have metric threads lol. It makes sense if they switched to a metric stud in late 80's (^didn't read that part previously), the adapter I got from Ike, he said it was from a 70's or early 80's 1 ton Dodge IIRC. The threads in this bowl are standard coarse thread. Also, FWIW, 04505365 is slightly different and shorter than the studs in other bowls I have around the shop.
Iz69, if you have a link for the other standard thread stud, please post it. Thanks.
Bill Gilbert
bgilbert
