Upper 2WD Ball Joints
Postby Diesel » Sat Jan 24, 2015 10:44 pm
Man those threaded in ball joints are a pain. I got all other bushings and ball joint pressed out. Unthreading that top ball joint is damn near impossible. I wasn't able to make it budge on the truck so I finally took the arm off. Would anyone have a suggestion? I could use an angle grinder to notch it and then use a chisel to try and get it to turn. Any other ideas? I don't want to get out the acetylene because it will ruin the arm.
1991.5 D250 Intercooled A518
Diesel
Re: Upper 2WD Ball Joints
Postby oldestof11 » Sun Jan 25, 2015 9:18 am
New, and upgraded, A-Armsare available on EBay.
That said, I used an electric 3/4" impact. Spun them out after a few hits.
Postby Diesel » Sun Jan 25, 2015 1:17 pm
I wonder if the ebay ones are any good (non-oem i mean)?
Diesel
Postby oldestof11 » Sun Jan 25, 2015 1:39 pm
I like mine. For the time I put into pressing 1 set of bushings and 1 upper balljoint, I should have bought the new A-arms in the first place.
Postby Diesel » Sun Jan 25, 2015 3:33 pm
Haha now you tell me!
How many miles you have on your eBay arms?
Diesel
Postby oldestof11 » Sun Jan 25, 2015 3:51 pm
Around 500 miles now.
Andy (dazed&confused) I think runs them in the Duck. A guy on CF has had them for +2 years now.
Postby Diesel » Sun Jan 25, 2015 4:15 pm
Thanks. Theres a post over on CF too and it seems like the aftermarket arms get good reviews there too. It goes against every grain of my being to buy Chinese arms for my first gen but they are $89 a pair with free shipping compared to $170 each for Mopar!
Diesel
Postby oldestof11 » Sun Jan 25, 2015 4:19 pm
It is, in my opinion, not so much the Chinese quality on something like this that is in question but machining. Chineseium is getting better at casting and pressing but tight tolerances are lacking.
Postby Diesel » Sun Jan 25, 2015 5:20 pm
They really do use some junky metal too though. I've had some chinese things bend that really shouldn't. Had these parts not come with the recommendation of someone else I wouldn't do it...heres to hoping these keep my truck as dead nuts reliable as its been.
Diesel
Postby dazedandconfused » Sun Jan 25, 2015 6:00 pm
I don't run them yet but have looked into them. Chris (Skilletky) had put them on his 1st gen though. Its still running around.
Postby jdiesel_us » Tue Jun 09, 2015 8:53 am
I too am headed down this path, hope it does not take a wrong turn.
jdiesel_us
Postby tbidigare » Fri Sep 18, 2015 4:38 pm
What's the verdict on the import A-Arms? I've got a ball joint project in the new future and I'm trying to figure out my plan of attack.
tbidigare
Postby oldestof11 » Fri Sep 18, 2015 5:24 pm
15k miles later, the ball joints are junk.
The A-arms and bushings are holding up.
Postby tbidigare » Sat Sep 19, 2015 8:56 am
Well that sucks about the ball joints but good to hear about the A-Arm.
tbidigare
Postby Diesel » Wed Sep 30, 2015 7:04 pm
My A-arms are good. I didn't buy them with ball joints and bushings and pressed in my own Moog ball joins and moog rubber parts.
Diesel
