Adjustable Proportioning Valve
Postby josh_6bt » Fri Apr 03, 2015 8:37 am
Hey guys. I recently swapped a dana 80 with discs into my w250 and I bought an aftermarket Proportioning valve. I have deleted my RAWL and my wondering where do I plumb in my new PV? What is the aluminum junction block below the MC? Do I tap into the rear line under that?
1992 W250 EC, 5 speed, 3.54s, 175hp p-pump, timed @ 16.5, #100 fuel plate, 4k GSK, 5x14, .024 DV, head studs, 60lb VS, 4" exhaust, BHAF, cooler tubz.
josh_6bt
Re: Adjustable Proportioning Valve
Postby CumminsPower59 » Sun Apr 05, 2015 3:59 am
The aluminum block under the master is the original proportioning valve.
Postby Tacoclaw » Sun Apr 05, 2015 6:01 am
Yup, you completely remove the factory piece and plumb in the aftermarket in its place.
Postby josh_6bt » Sun Apr 05, 2015 9:39 am
Alright cool thanks guys.
josh_6bt
Postby 762frmafr » Wed Apr 08, 2015 5:43 am
Isn't the brake light switch part of the original valve? Would an aftermarket PV have a place to put the brake light switch? Anyone have a part number for the PV they used?
762frmafr
Postby CumminsPower59 » Wed Apr 08, 2015 10:19 am
Stop light switch? No. Prake pressure switch? Yes.
The stop light switch is mounted above the brake pedal. The switch you are taking about is for the brake light on the dash, it'll come on if pressure is reduced.
Postby 762frmafr » Wed Apr 08, 2015 12:00 pm
CumminsPower59 wrote:Stop light switch? No. Prake pressure switch? Yes.
Gotcha. That's kind of what I thought, but I saw a wire going to the PV and wasn't exactly sure what the switch was. Thanks a bunch.
762frmafr
