Speedo gone mad
Speedo gone mad
Postby Jelmer » Tue Jan 05, 2016 1:55 am
The speedo in our truck is gone mad. It was off a lot because it was missing the ratio adapter but tje needle was pretty stable. I've ordered the correct ratio adapter but didn't fit it yet because we need a "90ยบ knee" (anyone has one?). Last week the speedo needle started to bounce like hell when driving on the freeway. Th speedo unit is already rebuild in 2010.
Greetings from the Netherlands where there are only 2 or 3 1stgens!
93 D250 Cummins, G360, 4" stainless exhaust, BHAF, DennyT stage 2 pin, 3200rpm governor spring, 12cm housing, rest stock.
03 VW Bora 1.6
83 Datsun Laurel 4.5 32v V8
84 Nissan Patrol 2.8i
Jelmer
Re: Speedo gone mad
Postby ellis93 » Tue Jan 05, 2016 4:52 am
The speed sensor is likely going bad or loose. I've also encountered that happening when the wire connection would be oily or loose at the speed sensor
Re: Speedo gone mad
Postby Jelmer » Tue Feb 16, 2016 2:55 am
Ellis,
It's been a while but the speedo sensor is almost new. I also detected another, new issue: When I start the truck the speedo goes already to, let's say 40mph but i don't even drive yet!
03 VW Bora 1.6
Jelmer
