ramcharger gas tank in d350
Postby rockmike » Wed Apr 28, 2021 1:38 pm
Howdy folks.I got a 93 d350 and im wanting more fuel storage.I think I recall reading that guys fit the old ramcharger tank between the frame rails in the back where a spare tire might go.In addition to the factory side tank.
I searched and failed.
FWIW I have a slip tank in it now,but I need the bed space on my flatbed...so thats why I want more fuel storage between the frame rails.I could install a tank selector valve....but I think I would opt to run an electric pump on the back ramcharger tank to fill my factory tank when runs low.
Anybody got info on what year of tank (maybe buy a new Dorman tank if available)how this additional tank would be installed...I am fabricator so Iaint scart of fabbin stuff etc.
Thankyou so much for your help and knowledge,Mike.
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Re: ramcharger gas tank in d350
Postby Richie O » Wed Apr 28, 2021 3:01 pm
PToombs did that I think. PM him if he doesn't chime in.
Postby PToombs » Sun May 02, 2021 11:02 am
I pulled my tank from my 92 when I sold it, Have it installed in my 93 D350 dually now, just need to finish the hook ups. I made the brackets. What I need to figure out is how to fill it. I haven't got the plumbing worked out yet. I use the in tank pump to push it thru a water separator into the main tank.
If you want pics lmk, the box is still off so it's right there.
Postby Begle1 » Thu Jul 27, 2023 11:26 am
I installed a Ramcharger tank on my truck many years ago, and it's all I've been running on ever since to tell the truth.
I cut the fill door sheet metal off the donor Ramcharger along with the tank, and paid a body guy to install the second door in my bed. He did a great job and it really does look stock. I have the only two-fill-door Dodge I've ever seen but nobody ever appreciates it.
If you're still around I can provide pictures. Over the next couple years I plan to finish quite a bit of the outstanding projects on my truck.
