I've got a few things sloppy on my rear driveshaft, first is the diff U-joint, second, the carrier bearing looks pretty useless in its current state and the slip joint is worn.
I know napa has the U-joint and the carrier bearing, what do I do about the slip joint, though? I haven't cut the crimp-sealed boot on it yet, I was thinking about doing that so I could grease it. I'm pretty sure it ain't gonna be pretty and I probably won't want to put it back together after I see it. So I'm trying to plan ahead a little...can I get new parts or do I have to go find a driveline shop or something??
