by PToombs » Sun Mar 16, 2008 8:31 am
P-pump is the inline injection pump. Do you mean the piston pump? If the piston pump, there are 2 options, low flow, has 15 psi, Hi flow has 40 ? I think. I have the low flow on mine, holds 15-16 most of the time, unless I'm on it hard, then it drops to 10. You don't want more than that at the VE, or you can blow out the front seal, and fill the base with fuel. I would say put in a fuel pressure guage, at least temporarily, to see what you have, then go from there.
On the fuel level guage, the sender in the RC tanks may read different than the stock one. The one I have when full to the brim, reads right on the "F", not over, when it was empty, just installed, it read right on the "E", not below. The regular one will read just over F and under E.
Hook up the wires with them out, and manually run them from full to empty and see where they read, that's what I did.
