Wheel, back spacing, pictures
Postby redneckroot » Wed May 19, 2010 11:59 am
I'm going to be ordering wheels soon and am wondering what you guys are running for back spacing on aftermarket wheels. Pictures with the info would be even better. Thanks guys.
redneckroot
Re: Wheel, back spacing, pictures
Postby redneckroot » Thu May 20, 2010 5:44 pm
anyone? I know some of you are running aftermarket wheels.
redneckroot
Postby Richie O » Thu May 20, 2010 6:09 pm
My 89 has 16.5's but have not had the wheels off for years. :D
Postby Tintacker » Thu May 20, 2010 6:52 pm
When I was shopping for wheels, I was told our trucks run a 0 (zero) offset. As in the flange should be centered in the wheel, so the backspacing would vary depending on the rim width?
I'm sure someone here knows for sure.
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
Postby redneckroot » Sun May 23, 2010 6:09 pm
I'd like to have mine offset a bit, but I was hoping for some pictures with the backspacing so I could decide. Thanks for the replies so far.
redneckroot
Postby spencermumma » Tue May 25, 2010 7:31 pm
most of them have no offset i have 33 12.50 and they barely stick out past fender at all
1990 Dodge W250 5 inch stacks no muffler, Star wheel bottomed out, Smoke screw turned all the way, Fuel screw maxed, Denny T Fuel Pin, 2inch lift with 33x12.50 and alot more to come shooting for 450 horsepower any suggestions?
spencermumma
Postby redneckroot » Sat May 29, 2010 8:13 pm
Anyone have any pictures of their wheels and the offset?
redneckroot
Postby Tintacker » Mon May 31, 2010 11:11 pm
OK, These wheels are 16X8.5 with a -6mm offset (meaning the wheel is 6mm out from center), with 285/75 Nittos.
Hope this helps,
Tintacker
