Spindle Lock Nut
Spindle Lock Nut
Postby Towrocket » Fri Jul 02, 2010 10:40 am
Has anyone tried these? (X-lock spindle nut if the link don't work)
http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Product_Code=DNA-XX&Category_Code=AXL
They cost about the same for an oem replacement in my area. And they "sound" like a more solid option.
89 W250, SC, SRW, Daily Driver (mostly stock)
Towrocket
Re: Spindle Lock Nut
Postby kensmachine » Sun Jul 04, 2010 6:02 pm
I looked into them The last time I did my brakes. you need 2 kits to do an axle so that would be $120. I went to 6 States dist. and got the old style lock nuts and washer for about $40. time before I put new nuts and retainers on and was not happy with what I found when I took it apart the retainers bent over so that tells me the nut was on the move witch is not good. Ken
kensmachine
Postby dpuckett » Thu Jul 15, 2010 7:27 pm
WHat's wrong with the OEM pair of nuts, with the washer between the two? (Pete- zip it!!)
DP
Postby PToombs » Fri Jul 16, 2010 4:30 pm
No problem Dan. So not going there! ;) :lol:
