frame
frame
Postby gobigorgohome » Fri Sep 17, 2010 11:09 pm
i have heard from several people over the lasst year that in the first gen dodges there was a problem with the frame bending when pulling under normal load. i have 2 questions to this. 1, were they actually pullin normal load or way too heavy and 2, is this a common problem to see or not? what should a person be on the watch for?
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Re: frame
Postby ellis93 » Sat Sep 18, 2010 4:26 am
My truck will flex some. Noticed that between cab and frame. Seems normal though. I have also notice that right rear of my bed sits a little higher than my left side parked on level ground.
Re: frame
Postby BobS » Sat Sep 18, 2010 4:47 am
Read what the owners manual indicates as maximum combination weights and then read again what the ones with problems were pulling. Excessive tongue weight on a bumper hitch WILL in time make the frame see this as multiple mini collisions and the built in impact crush zones over time will act as they were designed to do in the event of a collision. You can pretty well assume that the trailer is severely overloaded for the truck when the tongue weight causes the frame to bow upward ahead of the rear wheels. Also note that in the rust belt of North America that most of the frames of these trucks have been slightly hampered by rust.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: frame
Postby gobigorgohome » Sat Sep 18, 2010 9:10 am
ok thanks for the info guys, if yall hear anything else id love to hear about it
gobigorgohome
Re: frame
Postby Mark Nixon » Sat Sep 18, 2010 8:16 pm
Having scrapped my share (and then some) of these trucks, I've also noticed that the earlier, pre-'92, 3/4 ton "short" frames are susceptible to cracking.
It tends to happen behind the rear of the cab, on the driver's side.
I have also noticed on several occasions where the framerails over the rear axle have been torn from the top edge of the rail through the mid-point of the rail, with evidence that the rear bumper likely dragged.
THAT'S a real sight to see, and a definite sign of gross overloading.
Re: frame
Postby ellis93 » Sat Sep 18, 2010 8:28 pm
Mr nixon did the trucks that had the torn frame over the axles have the over loads on top of the spring pack.
Re: frame
Postby Mark Nixon » Sat Sep 18, 2010 8:57 pm
Not all had the overload strikers, but the last one that I had that did that was a 1990 1 ton Cab and Chassis, that was SEVERELY abused.
It had the overload strikers and they had even been replaced.
So had the rear spring packs.
