Rear upgrade options
Postby cumminz90 » Thu Sep 23, 2010 6:02 pm
The posi unit in the 93s going bad rather than fix the rear and chance something breaking again id like to put something heavier and better under there such as a dana 80 that wont go bad or hafta worry about breaking all the time. truck will see the sled quite a bit so i want something that will survive that and daily driving. Question is is there any other rears that would work good for this wear i could retain my 3.54 gear ratio? And wat type of vehicles are the dana 80s found? Thanks for the help in advance :grin:
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Re: Rear upgrade options
Postby ahale2772 » Fri Sep 24, 2010 1:00 pm
your best bet is one from a 2nd gen dodge i know many came with d80s, and ud get disk brakes
Postby Richie O » Fri Sep 24, 2010 5:14 pm
ahale2772 wrote:your best bet is one from a 2nd gen dodge i know many came with d80s, and ud get disk brakes
Some of the 2nd gens used a 70 so check it out. Also the disk brakes are a fairly new thing. The older 2nd genners have drums.
Postby dpuckett » Fri Sep 24, 2010 6:05 pm
2ndGens up to early 02 had outboard drums (think of a 1/2ton style drum removal).
If it had a 5spd and a diesel, or was a dually, with a diesel, it has a D80. The only ones that had a 70 were the 2500 autos.
DP
Postby ahale2772 » Fri Sep 24, 2010 6:29 pm
didnt all the 24v 2nd gen trucks come with disk?
Postby ellis93 » Fri Sep 24, 2010 6:35 pm
Some sport trucks(the high dollar) had them the father in laws has them and its a 2000.
Postby cumminz90 » Sat Sep 25, 2010 3:21 pm
when your looking at the trucks rears is there a big ( or distinguishing that you can you can tell right off the bat which is which) difference between the 70 and 80 Rear and thanks for all the info guys keep it coming
cumminz90
Postby ahale2772 » Sun Sep 26, 2010 3:09 pm
the 70's diff cover is almost a square/ diampond shape while the 8o is taller than it is wide
Postby pulltilbroke » Sun Sep 26, 2010 9:30 pm
V10 5spd and duallys also had D80s
Postby cumminz90 » Mon Sep 27, 2010 3:14 pm
sweet thanks for the info should make it easier to locate one now :D
cumminz90
