Front end shimmies
Front end shimmies
Postby lectro_static » Sun Oct 24, 2010 4:48 pm
Not all the time but at medium speeds I seem to have a front end wobble. Seems to be when I go over a small bump like a man hole cover or when I am turning it will wobble for a bit after I straighten out the wheel. I have new front brakes, new drag link and really dont see anything wrong. Any ideas on where to start so Im not just throwing money at it and hoping?
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Re: Front end shimmies
Postby PJ 3 » Sun Oct 24, 2010 5:15 pm
I'd block up the front end and get a buddy to turn the steering back and forth while checking everything. Could be a bad bearing to. I know that my truck had a bad bearing in it and it did that.
Pete
1992 W250
PJ 3
Postby ellis93 » Sun Oct 24, 2010 5:17 pm
Knot on a tire or maybe a loose track bar. :?:
Postby Richie O » Sun Oct 24, 2010 6:53 pm
Any front end issue can cause this. I had a truck with some slop in the tie rod ends and it would only shake under the right conditions. My 93 has bad rotors and once in a while when I hit the brakes it will set it off.
Postby cougar » Mon Oct 25, 2010 9:55 am
This is one that can drive you crazy. As Richie O said, it can be a lot of things in the front end. What got me, is after rebuilding the front end and doing some front frame work on my 91 I still had the shimmy. Turned out to be my rear brakes doing this catch and release thing. Shortly after I picked up a 92 that was doing the same thing. Fixed the rear brakes and it went away on that one as well. The symptoms can be can be hard to track down so don't expect it to be easy. Fix the obvious first and go on to the next. Not sure if it was this forum or another I posted a list of what all I did on the front end, but some of it wasn't the usual. Check the forward leaf spring mounts to the frame for looseness. Cracked steering gear mounting plate is common. Mushy or worn out bushing in the leafs. Loose U bolts. Could be just your steering coupler or a bad shock.
01 2500 "the work truck".
cougar
Postby lectro_static » Tue Nov 09, 2010 11:19 am
Jacked up the truck and the only thing that seems bad is the steering coupler at the box seems a bit loose. Would that cause the tires to go crazy only at certain times? Seems to me it would be all the time but I cant find anything else it could be.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby PJ 3 » Tue Nov 09, 2010 5:20 pm
lectro_static wrote:Jacked up the truck and the only thing that seems bad is the steering coupler at the box seems a bit loose. Would that cause the tires to go crazy only at certain times? Seems to me it would be all the time but I cant find anything else it could be.
That's what my truck did with the worn steering coupler also. I installed a borgeson and the problem disappeared. The steering box bracket was cracked also and changed at the same time so I really don't know the exact source but more than likely the coupler was my culprit. Couger hit the nail on the head saying this one will drive you crazy........it's all about a process of elimination :roll: I'd fix the coupler and go from there !
Pete
1992 W250
PJ 3
Postby lectro_static » Fri Nov 12, 2010 4:45 pm
Put in a steering u joint, woodward piece I cut the factory shaft and welded the u joint to it. Drag link is aftermarket, tie rods appear to be good. Could the sway bar cause it? I did put lift shackles on it just a bit ago.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby CO cummins luvr » Fri Nov 12, 2010 10:28 pm
shocks, missing wheel weight
93 W250 C/C NV4500 rear disc conversion
CO cummins luvr
Postby lectro_static » Sat Nov 13, 2010 2:03 pm
Thought I got it, steering box needed to be adjusted. It wasnt really sloppy but just enough to make it shimmy at times. Still does it and it only does it under light to no throttle.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby cougar » Sun Nov 14, 2010 9:28 am
lectro_static wrote:Thought I got it, steering box needed to be adjusted. It wasnt really sloppy but just enough to make it shimmy at times. Still does it and it only does it under light to no throttle.
Check ALL of your U joints. Both drive shafts and front axle. I had one that would bind a low speeds and start bouncing the truck. One on the axle can induce a shimmy even with the hubs unlocked.
cougar
Postby lectro_static » Tue Nov 16, 2010 5:56 pm
How can I check my kingpins without tearing it all apart?
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
