vac pump removal issues
Postby manyholes » Fri Dec 17, 2010 4:31 pm
working on this hydroboost swap myself with an 03-04 gm hydroboost unit, hoses and cooler, problem with powersteering pump, i bought the 2000 dodge pump but cannot get my vac pump to seperate from the powersteering pump, one nut was siezed, ended up cutting the stud off and got the other 3 nuts off. is there a trick to removal of the pump or?? tried penitrating oil, very little heat due to vac being aluminum. this is on my 90 w250 with the dual diaphram pump, i have a newer style vane vac pump with the two bolt flange for pump, but the 2000 pump wont bolt to it.
when trying to separate the pump from vac, i only get movment till the gear bottoms out the vac case, so im guessing that the cogs are siezed together. any help is apreciated.
is there a p/s pump that has hydro boost that will work with newerstyle vac pump, i believe the other vac pump is off a 91 with the 2 bolt flange for p/s pump
thanks alot
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: vac pump removal issues
Postby Mark Nixon » Mon Dec 20, 2010 12:46 pm
If it's a factory 1990 Vac/P.S. pump assembly, they are pressed together.
The 2000 power steering pump is not compatible with the '90 version.
If you can get the other part of the 2000 style pump assembly, I'd do it, otherwise you could plumb pressure and returns using hydraulic fittings and tees on the stock 1990 Power Steering set-up.
Postby manyholes » Wed Dec 22, 2010 5:07 pm
Got the newer syle pump and adpter for the truck. Thanks for the input, can I cut the lower support bracket for the throtle linkage withouit renforcing it? To fit the newer pump assembly. Thanks for the help
manyholes
Postby Mark Nixon » Wed Dec 22, 2010 5:13 pm
You can cut the lower end off.
Find a way to re-support it, if you can, though.
