powersteering pump q's
Postby manyholes » Wed Dec 22, 2010 5:12 pm
Is it possible to remove the machined cog off the end of the power steering pump? Is it pressed on or threaded? If threaded, left or right jhand threAd? Thanks for the help
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
