First time drag racing!
Postby gear jammer 91" » Sun Jul 06, 2008 1:23 pm
I went out to the local track and made a couple passes last night in the 1/4. The best I was able to do was a 15.8 @ 87. That was leaving around 1k rpm and rollin onto the power, if I left any harder it would just spin. Without a tack and being to afraid of tranny carnage to launch in 4x4 made it tricky to put down a good run but I still had a lot of fun, and I smoked my buddies big pretty power stroke! My best 60' time was 2.4, 1/8 was 10.2 @ 71.3, 1/4 was 15.8 @ 87.2. Schandler was also their. His clutch didn't like his 4x4 launch though. His best racin me was 16.9 @ 81.06, I don't know if he was able to put up a better number before his clutch started slippin. Here's a video of our first passes. I spun pretty good leavin on this one and olny ran a 16.2, my 60' time was 2.79 :oops: I'm in the far lane in the silver truck and Schandler is in the near lane in the red and silver truck.
01 LB7
gear jammer 91"
Postby oldcool90 » Sun Jul 06, 2008 1:38 pm
Launch it in 4wheel drive.My 727 held up just fine, and that was with 35 in tires. I would build about 5 to 10lbs of boost then launch it :D :D.
oldcool90
Postby gear jammer 91" » Sun Jul 06, 2008 3:34 pm
I'm really concerned about my getrag being able to take it. My clutch should be up to the task though, it's a con ofe. My getrag has some slop in it when I get on or off the throttle, I've checked the U-joints and the rear end for play and I'm pretty certain its in the tranny. :sad:
01 LB7
gear jammer 91"
Postby SChandler » Sun Jul 06, 2008 5:42 pm
The first pass was the quickest. My second pass was an example of how not to launch (almost killed it at the light :oops: ) and was an 18.2 at 80.7mph. The third pass was better starting off (.264 r/t with a 2.439 60 foot) but the tach never came off of 3000 rpm the entire way down the track. Ended up with a 17.921 at 69.96mph for the third and final pass of the night. I need more clutch before I go back to the track :evil: . The first two passes exhibited some minor clutch slippage, but the final pass was slipping almost the entire time.
SChandler
Return to Competition
