Time for new turbo!
Time for new turbo!
Postby ryanihf250 » Mon Sep 15, 2008 4:02 pm
On my first pull last month I blew stock turbo. There are so many different options out there. I was wondering what might work best for my truck. Our classes can run nitrous so I can give it a sniff to help the turbo spool. I know many people are running Custom S-300 but I would like other options. Has anyone tried a Stage II turbonectics on a 1st gen.
I just don't want to buy a turbo that I can't spool
Thanks
Ryan
Playtoy:1992 Dodge 350 4x4 SRW Cummins. 6in lift, 35in Pro Comp X , Dana 80 swap 4:10 Pump maxed, BHAF, 6x16inj, 3200 GSK, Piston Lift Pump, II SPS turbo.Street Pulling truck project. www.libertyantiquetractorpull.com
ryanihf250
Postby cummins king » Mon Sep 15, 2008 6:15 pm
Try a garritte GT35
93 4X4 auto
cummins king
Postby VEfreak » Tue Sep 16, 2008 4:56 pm
maybe bigger than that, if you nitrous to boot, try a garrett GT40R.
I AM ZUES DAMNIT
VEfreak
Postby fergavs » Tue Sep 16, 2008 6:28 pm
A Garrett Gt4088R would be a great turbo for you probably. It would support a set of big EDM sticks and a 14mm h/r. It should light pretty fast as it has a 64mm (aprox) inducer and a ball bearing center section. My turbo is a journal bearing 64/71/14 and it lights like nothing. I spin her up to 50psi no problem. It would be a fairly expensive turbo as it has the ball bearings but give her a try and let us know.
fergavs
Return to Competition
