it should look like that^^^ but without the space between the url and the [/IMG]
removing that space will post a pic, like this VVV
hopfully your pics arent as huh? as mine are.
PToombs wrote:Cam plug is in the rear of the block, on the cam galley. Like a soft plug, little different. They are just a dish shape, like you pushed the center down with a finger. The new ones have an o-ring you put in, then the plug seals against that. Install with some loctite, then whack with a hammer.
