74 W300 gasser pulling vid
Re: 74 W300 gasser pulling vid
Postby Philip » Tue Aug 10, 2010 5:58 pm
Bill
The rear barrells are coming in way to slow. Replace the secondary spring to at least a #2. You might even be able to use a #1.
Th engine didn't sound like it was laying down or anything. I think I got the jetting real close for what your doing with it.
Have you gotten a timing light on that engine yet??
Postby unixcowboy » Fri Aug 13, 2010 7:55 am
KTA wrote:Thats funny Bill. I think this tractor is only about 1/1000th of the diesel related projects I have going on. I hooked it again last night and won by 20feet. :D Its kind of fun going 300+feet without the front wheels ever touching the ground. Sorry there are no videos though that I am aware of. I think a max wedge 440 with 2 650 holley 4bbls should wake that rig of yours up. :grin:
When the 360 in my '87 gave up after 300K I put in a 440 from a '77 Imperial and swapped the rear gears for 4:11's.
Yanking around my 18K 5th wheel the engine was REALLY working so I found a dual-quad manifold and a set of Thermoquads that were supposed to flow 780CFM - that seemed like a lot but they flowed good. I also put in a truck cam for a 440 - it was a '60something...
THAT woke up my truck - - It would rev to 5800 with the trailer attached - and quick....It would hit 5800 in 2nd - - -
ONCE only - with 40ft of RV behind you that's a THRILL I can do without again :lol:
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby PToombs » Fri Aug 13, 2010 6:16 pm
unixcowboy wrote:..- with 40ft of RV behind you that's a THRILL I can do without again :lol:
Oh Larry, where's your sense of adventure?! :lol:
Return to Competition
