A little disapointed.
Postby Rampower » Sun Aug 05, 2007 2:24 pm
But we still had fun. The old girl didn't run down the 1/4 like I had hoped. She seemed to be low on power. My best time was 13.95 1/4.
with a 1.8 60 ft. I think that I am going to have to go back to the drawing board and see where I went wrong, or what went wrong. I am running the same temps and boost as I was before I went north to race, but the power is not there, and there is an exhaust leak at the manifold somewhere. I guess it's time for aa HTT 3 piece manifold now.
92 ext cab 4x4. HT62-14, 4" straight pipe, BHAF, O-ringed, Haisley head studs, Ported head, exhaust, and turbo. Fuel pin, 4,000 gov spring,
Rampower
Postby KTA » Sun Aug 05, 2007 10:17 pm
Well it sounds like at least it is still in one piece!! I am now waiting for Bill to come along with his I told you so hat on about the 4k gov spring. LOL
Postby PToombs » Mon Aug 06, 2007 4:56 pm
Yeah, he'll latch on to that like a junkyard dog on a tire! :lol:
Postby Rampower » Mon Aug 06, 2007 7:42 pm
I'm not totally convinced that it is the 4200 yet. She ran a lot better before the drive up. I drove her pretty hard going north for 150 miles. We will just have to do a little inspecting to see what we can find. If it is the 4200 spring, then out it comes. I do know that she rolls a lot more smoke after the trip than she did before, just have to figure out what changed.
Rampower
Postby KTA » Tue Aug 07, 2007 7:17 am
Check exhaust manifolds and your wastegate. You might need to check your intercooler and gaskets on tht side too. More smoke shure sounds like a boost issue.
Postby PToombs » Tue Aug 07, 2007 2:11 pm
Maybe your I/C popped a hole. I didn't have a clue mine was bad until I hooked up the gooseneck and put the little tractor on. About 6500# total. It always had 16 psi and EGT's were reasonable. When I left with the trailer, EGT's were thru the roof! Turns out the I/C was cheesecloth! :roll:
Postby Rampower » Wed Aug 08, 2007 7:35 am
Beings this is the factory innercooler and boots, I guess there might be a chance that it could have a leak :lol: I am going to preassure test the system this weekend and find out. I'll keep you guy's posted.
Rampower
Postby Rampower » Wed Aug 08, 2007 7:36 am
I dont know why this durned thing keeps posting my stuff twice.
Rampower
Postby PToombs » Wed Aug 08, 2007 5:12 pm
After you press enter the first time, even if it doesn't go to the screen that says "message entered successfully", "view response or index", it still posts it. If you get the "error, invalid..." whatever, go "back" to the thread, and refresh and the post will be there. If you go back to "message" and hit "enter" again, you get double post.
I hope that makes sense, I almost cornfuzed myself! :lol:
Return to Competition
