another pull with the old truck,video
Postby nova6511 » Sun Sep 25, 2011 1:36 pm
Pulled this time with no AFC.Had a pretty good run going and blew a boost boot at 275'.
http://www.youtube.com/watch?v=wbRqoNPkHJE
nova6511
Re: another pull with the old truck,video
Postby oldestof11 » Sun Sep 25, 2011 5:59 pm
It was going good!
2000* EGT :?: :?: :?: :?:
:shock: :shock: :shock: :shock:
Postby Hansen01 » Sun Sep 25, 2011 6:06 pm
:alien: :shock:
Under construction...
Hansen01
Postby nova6511 » Sun Sep 25, 2011 6:33 pm
Ya I know it is very hot,running a HE351 and its not getting the heat out fast enough plus I welded the gate shut so no help there either hints why I was so high on the boost side also.
nova6511
Postby oldestof11 » Sun Sep 25, 2011 6:43 pm
nova6511 wrote: I welded the gate shut...
There's the source of +70psi... :shock:
It has a 9cm housing on it. Good enough for 2.9L V6 gassers hitting +30psi at 3500 rpms...
At that pressure, you are in massive DANGER of the compressor or turbine wheel either disintegrating or exiting via the hood.
Postby nova6511 » Sun Sep 25, 2011 7:05 pm
That was its last pull.This turbo has stood more then any one ever thought it would including me.
nova6511
Postby The_Head » Sun Sep 25, 2011 9:11 pm
Cool vid!
The_Head
Postby nova6511 » Mon Sep 26, 2011 5:10 pm
Thanks.
nova6511
Return to Competition
