P pumping
P pumping
Postby redneckroot » Mon Sep 22, 2008 7:01 am
I'm in the debate of P- Pumping my truck mainly because I want to be able to do well at the truck pulls. What is needed to P- Pump my 90? I know I need a pump, gear, and timing housing. Do I need lines? What about injectors? Will my head work or do I need that too? I want to see how far in the hole I will go before I decide whether to do it or not.
redneckroot
Postby KTA » Mon Sep 22, 2008 8:27 am
It is usually always chepaer to just buy a 96 or 97 complete engine and swap it than to get all the parts you need to convert a 1st gen engine. ;)
Postby JQmile » Tue Sep 23, 2008 5:08 pm
It depends on how good at rigging stuff up you are. As far as I know you need:
1.pump
2.front cover
3.gear
4.lines
5.linkage
Talk to SMOKIN93 here on 1st gen, he just converted his over and said it wasn't that hard. The pump will be the main expense, it'll be about 500-1000 for the pump alone if it is in good order and a 180 or 215 pump, I think 160s go for a little less.
JQmile
Postby redneckroot » Tue Sep 23, 2008 7:41 pm
What i'm looking at is right now i have the motor out of my truck and with the purchase of my 05 I was thinking about going full out with this one (or atleast as full out as i can go on limited money). I'm just wondering if it would be better to spend the money to P pump it now then dump money and a ton of time into the VE to never be able to achieve the same power. Its not that I don't want to run the VE its just I want to make the most power for truck pulling as I can.
So here is what I'm seeing that I need, pump, gear, cover, lines. But do I need to also replace the injectors with 2nd gens? If so will they fit in the 90 head? I'm new to diesel stuff, but racing cars has gotten out of my price rang so its on to truck pulling.
redneckroot
Postby RumbleFish » Tue Sep 23, 2008 8:50 pm
i have the front cover, gear, and lines. get them out of my way, make me an offer.
Postby PToombs » Wed Sep 24, 2008 5:30 pm
And I can bring them back for ya when I come.
If you buy them before I go to SOP. ;)
Postby RumbleFish » Wed Sep 24, 2008 5:59 pm
oh snap, its gets even better!
Postby bgilbert » Wed Sep 24, 2008 6:12 pm
RumbleFish wrote:i have the front cover, gear, and lines. get them out of my way, make me an offer.
$20 ;) !!!
Bill Gilbert
bgilbert
Postby Ramrod90 » Wed Feb 18, 2009 10:38 pm
You will need 2nd gen injectors for the pop pressure and the line connection but they need to have 1st gen tips in them for the spray angle.
90 w250 LE, pump turned up, 4" turbo back, I/C conversion, 366 GS, DennyT pin, 6x18's, BHAF, soon to come... 6" stacks and built head.
Diesel is more than a fuel... it's a way of life
Ramrod90
Postby cedardiesel » Thu Mar 05, 2009 5:24 am
I didn't think that 2nd gen injectors fit in 1st gen head cause the bodies are different
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby DTanklage » Thu Mar 05, 2009 9:25 am
if ya do what kta said and buy a 96 or 97 engine it will be a lot easier and prolly a lot cheaper too
you'll have your inj bodies n all
dont look at that motor wrong tho....or you will have too much fuel for your low dollar combo
don
ps - all out and limited dollar dont really belong in same sentance
DTanklage
Postby cedardiesel » Fri Mar 06, 2009 5:48 am
Well can you make pop pressure the same as the 2nd gen injectors using the 1st gen injector bodies also what is the pop pressure set as
cedardiesel
Postby Ramrod90 » Fri Mar 06, 2009 9:26 am
No, because the p-pump injector lines are bigger and they won't thread on to a 1st gen injector body. Just get a set of stocker 2nd gen sticks and throw a set of 1st gen tips in, easy day.
Ramrod90
Postby cedardiesel » Sun Mar 08, 2009 8:04 pm
Ok thanks
cedardiesel
Return to Competition
