TWorlines' 349/792 Dyno Run
Postby TWorline » Mon Sep 22, 2008 5:08 pm
I put my truck back up on Dunbars Dyno @ the Indy 4 Wheel Jamboree and did 349HP/792TQ. I still have not had time to get that fulcrum lever changed, maybe this week so I can dyno again at the Buckeye Blackout 2008 in Zanesville, Oh. on Saturday. Josh the dyno guys told me all about your runaway, WOW! :shock: Here is a short jerky video of my run.http://s116.photobucket.com/albums/o28/DieselRam250/W250%20Videos/?action=view&current=S5009447.flv
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby JAyers » Mon Sep 22, 2008 8:04 pm
looks good! Why are you changing the the fulcrum lever? It already has a 205 pump doesnt it? Yea i think dave stained my seat for good, he pulled my shut down lever plum threw the damn dash. lol
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby oldcool90 » Tue Sep 23, 2008 3:38 pm
Hey Tim, if i known you was going to indy i would have went too. Couldn't find anyone to go,how was the show,dyno ,and the pull?
oldcool90
Postby TWorline » Thu Sep 25, 2008 6:28 pm
Josh:
I have a fulcrum lever out of a 2500 rpm industrial pump in there currently, will be out tomorrow though.
Matt:
Yeah I should have called you. :oops: The thunderstorm pretty much did the pull in. But there was alot of people there both days I was there. I also had the best pork chop I ever ate thanks to Kurtis and his brother! :rock:
Tim Worline
TWorline
Postby 921stgen » Sat Sep 27, 2008 10:54 pm
Hey Tim, thanks for compliment again and congradulations on the dyno run at the Buckeye blackout yesterday.
921stgen
Return to Competition
