Finally! A VE truck in the 12s!
Postby JQmile » Sun Oct 19, 2008 5:58 pm
Tom Collins ran a 12.66 today at the truck drags in Sacramento, CA. Small charger, lots of w/m and nitrous. 727 trans! Truck is 4wd.
JQmile
Postby mprmn08 » Sun Oct 19, 2008 6:19 pm
thats awesome. is there any video or anything?
mprmn08
Postby mtm93ramnasty » Sun Oct 19, 2008 7:00 pm
damn! id love to see a video of that
93 ctd pump maxed, little bit of timing, fuel pin ground, 3200 gov spring, 6x18 injectors, hx40, CoolerTubz, southbend con fe, isspro guages boost+pryo, 5in exhaust, home made intake w/greens airfilter
340hp 739tq no ksb hot wire stock lp
mtm93ramnasty
Postby Begle1 » Sun Oct 19, 2008 7:16 pm
About time.
Postby JQmile » Sun Oct 19, 2008 7:54 pm
It looked pretty sweet, nice and smooth! I think there will be vids somewhere later.
JQmile
Postby mhuppertz » Sun Jan 04, 2009 7:51 pm
JQmile wrote:It looked pretty sweet, nice and smooth! I think there will be vids somewhere later.
I'd love to see video also!
mhuppertz
Postby peobryant » Sun Jan 04, 2009 8:50 pm
I wish we could get a VE truck in the 12's on fuel only, but still it's pretty impressive.
Postby burnt_servo » Sun Jan 04, 2009 10:25 pm
what hp level does it take to reach the 12's for a 4x4 first gen ?
'93 w250 .... stock ...
burnt_servo
Postby KTA » Mon Jan 05, 2009 7:15 am
That depends on how heavy it is. 8)
Postby GLHS » Wed Jan 07, 2009 12:04 am
I will throw some numbers at you.
Most autos will get into the 12s if they can trap 102 mph.
A manual will need 2-4 more mph to do the same.
Elevens are a different story. I think most autos need 112 and a manual will probably need 116-119 mph.
Here is the FLYWHEEL hp needed to trap these speeds at this weight. I think my rwhp is 15% less than crank hp. An auto may be different.
5000 lbs (includes driver): 90mph=284 hp; 95mph=335; 100mph=390; 105mph=452; 110mph=519; 115mph=593.
6000 lbs: 90mph=341; 95mph=401; 100mph=468; 105mph=542; 110=623; 115mph=712.
7000 lbs: 90mph=398; 95mph=468; 100mph=546; 105mph=632; 110mph=727; 115mph=831
Brian; what did your truck weigh when you went 110? 6900? :shock:
My truck wieghed 6500 when I went ALMOST 104 which = 570.
If the Scheid dragster weighs 2000 lbs (I bet it's more) it takes 1305 hp to go 203 in the 1/4.
If it wieghs 2250 @ 203 mph = 1468 hp.
GLHS
Postby KTA » Wed Jan 07, 2009 9:17 am
My truck usually scales just shy of 7300 with me in it. I probably had a half tank of fuel that day so I might have been in the 7150-7250lb range.
Postby RSWORDS » Wed Jan 07, 2009 5:04 pm
Damn Brian... Imagine what that engine could do in a "light" reg cab 4wd with a 47RH behind it!
RSWORDS
Postby GLHS » Wed Jan 07, 2009 7:28 pm
KTA wrote:My truck usually scales just shy of 7300 with me in it. I probably had a half tank of fuel that day so I might have been in the 7150-7250lb range.
COWABUNGA FOLKS! :shock: :shock: :shock:
That's 742 hp at 7150 lbs.
Project "Rusty nitrous bucket" @ 5000 lbs could do a 11.00 @ 124!!!!!
On diesel only no less.
Another question Brian. I'm curious if your 110 mph run was the same run when you did 93.6 in the 1/8.
If so you must have broke or something because you should have trapped around 115 mph. No?
GLHS
Postby KTA » Wed Jan 07, 2009 8:06 pm
They were not the same runs, but typically it would run 91-93 mph in the 1/8. I suspect there is considerable wind drag at 110 so it probably is holding it back pretty good on top end. I drove my crew cab on the scales last night and it only weighed 5300lbs no driver. I thought to myself wow if I could ever get took off this thing would be fast with the motor out of old yellow. :lol:
Postby GLHS » Wed Jan 07, 2009 8:28 pm
DO IT! DO IT! DO IT! DO IT! DO IT! :D :D :D
GLHS
Return to Competition
