Running against a powerstroke
Postby Ezra » Tue Mar 31, 2009 7:00 pm
Ok I plan on racing a guy from work,After the new headgasket and studs are in.He's got a 2003 f-250 with intake and a superchip(I belive).Have you guys raced many Powerjokes? what kinda luck did you have? Ezra
93 W250,auto,3.54's..167k miles..asa modified intake.stans 4in,.industrial injection pump.6x.016's..S300 62/71/14..piston lift pump..And still more to come.
Ezra
Postby pulltilbroke » Tue Mar 31, 2009 7:31 pm
I'm sure your truck will eat that Powerjoke for lunch
Postby Richie O » Tue Mar 31, 2009 7:37 pm
I know you had an issue of it being slow for all the mods you have. You get it figured out yet?
Postby Ezra » Tue Mar 31, 2009 7:53 pm
Not yet.Still only hitting about 28psi boost.trany is slippin some though. :evil: .It's getting a new gasket and studs.and then turnin the pump up the rest of the way.Still thinkin I should be seeing 40+psi.
Ezra
Postby soggy » Tue Mar 31, 2009 11:28 pm
Launch at about 5lbs in 4wd and then make sure you go back and help clean up the mess from his blown head gasket :D
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby PToombs » Wed Apr 01, 2009 5:07 pm
After reading the 1st post I thought HE was doing a head gasket and studs. :lol:
Postby DoWhat? » Wed Apr 01, 2009 6:42 pm
7.3 or 6.0? The 6.0 might give you a run for your money. '03 had both motors available.
-91 W250 day cab 5 speed
strait pipe, monkey pump, big tires
-96 Ford F-250 PSD
strait pipe, big injectors, tunes
DoWhat?
Postby fergavs » Wed Apr 01, 2009 6:51 pm
I havent had a powerstroke come close to keeping up with my duallie yet. Hell my 4x4 will smoke almost any Superduty. The only SD that has impressed me so far is a 08 running around here with DPF delete, egr block off, and Spartan software. That truck is stupid fast!! Anyway you'll kill the SuperDuty. You should have 400+hp to the wheels and he'd be lucky to have 300rwhp. Plus your probably 1000-2000lbs lighter. Smoke em.
fergavs
Postby Ezra » Thu Apr 02, 2009 6:38 pm
PToombs wrote:After reading the 1st post I thought HE was doing a head gasket and studs. :lol:
I'am the one getting the Gasket and studs. :D and it's a 7.3...Ezra
Ezra
Postby soggy » Thu Apr 02, 2009 7:00 pm
Oh a 7.3, you'll waste him and then you can just leave, if it was a 6.0 it would be the one needing the H/G
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby gear jammer 91" » Thu Apr 02, 2009 9:18 pm
I smoked a buddy's 7.3 by close to a second. He has a compressor upgrade, some kind of injector upgrade, a built auto, and we was running the race tune on whatever programmer he had. His truck is a four door on 35's. My truck was making 300hp then, maybe less. He got me out a the hole on every run, but I was caught up to him just past 60', and around him by the 1/8th. I love putting a hurting on $25k trucks in my $5k truck. :lol:
01 LB7
gear jammer 91"
Postby ford69557ci » Thu Apr 02, 2009 9:37 pm
There is a reason they are called powerjokes. On a powerjoke big twins, custom dual hpops, huge injectors, highflow fuel system, and tons of nitrous gets a whole whoppin mid 11 sec pass. Booo on them lol.
ford69557ci
Return to Competition
