Diesel Modified-class Tractor Pullers
Postby Begle1 » Mon Feb 26, 2007 12:05 am
Not the Modified class of the DHRA pulls, but those full-custom monstrosities that the USAP runs with the 4 supercharged 528 hemi's.
I haven't been to any of the big boy pulls in a few years, but from what I recall they were all running either V-8's, V-12's or turbines. Why no Diesel?
Postby KTA » Mon Feb 26, 2007 6:55 am
Because the diesels have to low of a power to weight ratio. Say you ran a 505 SSD setup that makes about 2500hp if its right, or 27-2800 if you lean on it pretty good. Those engines with the 3 chargers will weigh about 2500lbs each so thats 5000lb. For the same weight you can run 4 2000hp blower hemis. So you can have 8000hp alky or at most 6000hp diesel, which would you choose? :twisted:
Postby Begle1 » Mon Feb 26, 2007 4:19 pm
Aren't the modified pullers limited to displacement and not weight?
Readily-available Diesel's have the lower power-to-weight, but I think we can edge the gassers out in power to displacement... Right?
Postby KTA » Mon Feb 26, 2007 4:44 pm
Unlimited Modifieds are limited to 7500lbs, from there they can run any engine combination they want pretty much. The current modified champion runs 4 chevrolet based engines, and the former multi time champion whose tractor is no more ran 4 hemis at the end and prior to that ran 2 hemis and 2 chevys because the rules prohibited running 4 hemis. That was/is the grand national modified class, the unlimited mods were not that way, but run a VERY limited series. A guy from texas ran 1 dt466 IH diesel on alky with I think it was a hemi motor. He could only run those two engines because of the weight and It did decent but was not near the top of the class. Much like the old allisons and rolls royce motors they are cool but cant hang with the blower mountain motors.
Postby Begle1 » Mon Feb 26, 2007 5:38 pm
All right, didn't know that they were weight limited. Going by weight would make it a lot more open ended. :twisted:
Any bet until they will be competing? Based on the Audi R10, I think that ultra-modern Diesel's are rapidly approaching gassers in terms of power-to-weight. Although those supercharged Hemi guys have about 30 years of a headstart making them work right...
Postby JDGnut » Tue Apr 17, 2007 8:04 pm
Don Nelson's Machine... At least one engine used to be a diesel.. or parts of it were.. haha..
JDGnut
Postby KTA » Wed Apr 18, 2007 10:01 am
Nelson's Bullwhip had a Dt466 Ih on alky on it. No diesel fuel.
Postby JDGnut » Wed Apr 18, 2007 2:11 pm
Yup.. that's the closest to a diesel machine I could think of for a US Mod.. Go to Youtube.. and watch some of the European Mods.. they have some diesel Mods.. not very many.. but a few...
I want to see the a clip of the Fire Dragon run... (Then they get it on the track.... )
Bryan
JDGnut
Postby JDGnut » Wed May 02, 2007 10:57 pm
JDGnut
Postby LOGANSTANFORTH » Sat Jan 26, 2008 6:22 pm
remember guys those jet tractors are only running on high filtered kerosene......not that far from diesel......
jet tractors are the way to go, a motor only costs about 25k compared to bolting a new 575 blower motor together for 30-35K, with both motors set on kill, the blower motor will take about 10-15 runs (lucky to get 20) before the aluminum connecting rods work harden and they come apart, the jet motors will last almost indefinately......
Larry Roberts' DOUBLE STUFF unlimited tractor is running 2 alcohol drinking triple turbocharged DT466's and both his tractors ULTIMATE TOY and ULTIMATE TOY II run that class also but are running T-53 Lycomings......his other 2 tractors BIG TOY AND BIG TOY II (the alky tractors) both fit into the unlimited class though they are OPEN SS.....
THEY PUT THEM ON A PLANE TO SOME STRANGE AND FOREIGN LAND, THEY SAID GOODBYE TO MOM AND DAD AND HELLO TO UNCLE SAM, THEY NEVER THOUGHT THE DAY WOULD COME WHEN THEY MIGHT HAVE TO KILL A MAN, THEY DID NOT SLEEP A WINK THAT NIGHT BUT THEY WON FOR UNCLE SAM
LOGANSTANFORTH
Postby oldestof11 » Sat Jan 26, 2008 6:51 pm
I have 1 problem with the jet pullers, their LONG start up before the pull but still cool!
Postby LOGANSTANFORTH » Sat Jan 26, 2008 6:54 pm
about like trying to spool a A5K with a stock truck.........
LOGANSTANFORTH
Postby cummins king » Sat Jan 26, 2008 8:15 pm
off topic but this is a cool puller
look at the pipes on that baby
doent it make you want to cranck the tunes and go out and do one awsome burn out
93 4X4 auto
cummins king
Postby flashgordon » Sun Apr 27, 2008 2:46 pm
I thought about starting a new thread........but i'm not ever sure i can make the link work.
100psi in a cummins!
any body seen this
Hmmmm that didn't work. I have it saved in a file on my desk top.........But don't now how to send it that way either :oops:
It was sent to me in a e-mail, don't know how to post it here.
It was a pulling tractor with a cummin inline 6.......way bigger then our 5.9
and it split in HALF..........RIGHT AT THE CAM LINE. :hs:
Flash
flashgordon
Postby cummins king » Sun Apr 27, 2008 7:00 pm
ya this one
93 4X4 auto
cummins king
Return to Competition
