dennyt stage II fuel pin
Postby beerboy81 » Sat Apr 25, 2009 6:58 am
anyone know where i can get one?? 8)
Jake
'93 W250 LE '92 CTD/IC GETRAG 5sp. 4x4 4" lift 33x15.50x16 TSL/SX Super Swampers, Pumped up, ASA Mods, cooler tubz, 5" stacks.. 366 hiding in the glove box
beerboy81
Postby crewcabxlt » Sat Apr 25, 2009 7:22 am
i would suggest save your money,grind your own. put in a 366 governor spring .while your at it grind some off the afc lever. there is info and pics on several sites to do it. dtr has good pics.
crewcabxlt
Postby peobryant » Sat Apr 25, 2009 12:50 pm
Dennis is on www.dieseltruckresource.com
You have to sign up over there and shoot member DennyT a PM. They are $105 to your door.
As far as a stock ground fuel "cone" being better, I think the DennyT is better than even a heavily ground one, but you can certainly grind your own for some more performance.
Here is a DennyT vs. a stock ground cone...
http://www.youtube.com/watch?v=KoH_8CpmW5I
Postby beerboy81 » Sat Apr 25, 2009 7:32 pm
yea, i agree.. a buddy of mine has one in his ole farm truck, he ground his own and decided to try out some aftermarket ones and liked em a lot better. i guess it could depend on how good you are with the grinder :lol:
Jake
beerboy81
Postby SChandler » Wed Apr 29, 2009 4:31 am
crewcabxlt wrote:i would suggest save your money,grind your own. put in a 366 governor spring .while your at it grind some off the afc lever. there is info and pics on several sites to do it. dtr has good pics.
If you grind off the AFC lever, there's no need to grind the fuel pin as you've just made the fuel pin useless. The AFC and the fuel pin work in conjunction to regulate fueling with boost.
SChandler
Postby RSWORDS » Wed Apr 29, 2009 9:12 am
I run a DennyT in mine Jake. I Love it!
RSWORDS
Postby crewcabxlt » Wed Apr 29, 2009 10:45 am
i only grind a little off the foot , then the pin [cone] so i have afc control still.
crewcabxlt
Postby SChandler » Wed Apr 29, 2009 9:58 pm
crewcabxlt wrote:i only grind a little off the foot , then the pin [cone] so i have afc control still.
That makes more sense then. I was reading your previous post as remove the AFC foot then grind the fuel pin. :oops:
SChandler
Postby crewcabxlt » Thu Apr 30, 2009 7:40 am
ive tried alot of things with the afc and found better performance with the afc working,tuned properly. it may just be my elavation. we run another 1st gen with an auto, it will spool a little better with a different set-up. i dont have a problem with aftermarket pins. im pretty cheap
crewcabxlt
Return to Competition
