drag times and HP numbers
Postby jwatso8 » Fri Dec 04, 2009 1:35 am
hey guy's whats the fastest time, and hightest HP numbers you guy's have seen or heard of. :roll: thanks
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby peobryant » Fri Dec 04, 2009 2:27 am
Brian Block (KTA) made 627rwhp, fuel only with his truck years ago. Supposedly he made a run in the 650's too, but won't count it for some reason. STOMP made 630rwhp fuel only, and 680rwhp with W/M I believe.
Bill Gilbert made 556rwhp at Scheid this year, and JAyers made 516rwhp at the same event. I can't help you with drag times though.
Postby 1STGENFARMBOY » Fri Dec 04, 2009 7:31 am
I was there when Bill and JAyers made there runs and thats pretty big HP with a ve, they both hit my smile button. :D :D
Postby BC847 » Fri Dec 04, 2009 4:28 pm
I'll play . . .
A little slow off the line that pass with a 1.81 60'. A run later in the day had a 60' of 1.7599. :D
NO NOx!! ;)
Postby fatty » Fri Dec 04, 2009 4:56 pm
BC was your run #2 only or was it w/m?
Postby BC847 » Fri Dec 04, 2009 5:22 pm
fatty wrote:BC was your run #2 only or was it w/m?
There was a little 50/50% W/M (the W/M system is still set-up for 35ish psig boost. I've never gotten around to bombing it to properly support 60psig boost). The last time I dyno'd with the W/M specifically, it was good for no hp gain and only 60ftlbs of torque IIRC (before the 6x.016", cam and BHIC).
Don't you love all the fine-print excuses? :oops:
This dyno run was a couple of days before that 1/4 mile pass (#2 only, no correction)
Postby soggy » Sun Dec 06, 2009 3:31 pm
nitrous only? how'd you manage that? :lol:
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby peobryant » Mon Dec 07, 2009 1:13 am
soggy wrote:nitrous only? how'd you manage that? :lol:
The same way Banks does. :albino:
Postby 92 D/UNIT » Tue Dec 15, 2009 11:06 pm
David what gear ratio are you running in your truck?
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Return to Competition
