15.66 @ 90
15.66 @ 90
Postby Crossy's son » Sat Mar 27, 2010 12:53 pm
http://www.youtube.com/watch?v=D-bqbXDK7Js
not too bad for a slipping clutch and hoppin' off the line. wish you could hear it better in the video. flatshifting FTW
15.9 run VS. "JustRamIt", he lost his crossover boot at about 1/8 track and both trucks spun.
http://www.youtube.com/watch?v=YlqZ_njlIjw
It's not GHLS but we're tickled we broke the 15's
91.5 W250 5 speed, 500k miles, 3.54's, Powr-Lok, 4" Str8 Exhaust , Egt/Boost on pillar, 435 Injectors, Borgeson Steering shaft, HX35/12wg, 4" lift on 35's, dyno 5/18/13 302hp/792 tq
90 D250 727 3.07's 227k miles
Crossy's son
Re: 15.66 @ 90
Postby cumminz90 » Sun Mar 28, 2010 7:23 am
Sweeet times wat track was that?
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Re: 15.66 @ 90
Postby Crossy's son » Mon Mar 29, 2010 12:07 pm
Cecil county.
How's the truck(s) ??
Crossy's son
Re: 15.66 @ 90
Postby cumminz90 » Mon Mar 29, 2010 2:59 pm
Great im currently puttin the twins and pump on mine and jenns we drive everyday not a lick off trouble out of it :D
cumminz90
Return to Competition
