doubler transfer case
Postby stax25 » Sat Feb 05, 2011 5:56 pm
does anyone know of a transfer case doubler kit for a gen one with a 5 speed.
stax25
Re: doubler transfer case
Postby RumbleFish » Sat Feb 05, 2011 6:15 pm
Mad Max had one in his ctd ramcharger. idk how much he checks in here, but there is a huge build thread on it over on ramchargercentral.com
Postby stax25 » Sat Feb 05, 2011 8:26 pm
I am just wanting to find out becuase i am going to be changing my D350 to 4 wheel drive and am thinking about putting a doubler in
stax25
Postby BILTIT » Sun Feb 06, 2011 11:27 am
Derek B.
BILTIT
Postby wicked_stenH » Mon Feb 07, 2011 3:54 am
http://www.jedsmachining.com personal friend of mine, and in my opinion the strongest design out there. his website is minimal, but he will build to suit. he has built a pile of them for our wheeling club and withstand serious abuse. give jed a call and he'll fix you up.
wicked_stenH
Postby therabbittree » Tue Mar 15, 2011 7:47 am
The issue we run into is the 29 spline output on the manual trans output shaft. you can get a custom spud shaft that goes from 29 spline female to 31 spline make (advanced adapters makes one)and then use a 203 from a ford with a 31 spine female input. then you need a different 205 case also as the dodge 29 spline 205 has the race track bolt patteren under the getrag adapter. I have to dig up my research on this.. it is possible with some custom parts and lots of swapping. this is for a 203 /205 doubler. if you are doing a dodge auto the 23 spline 203 is a asy doubler job. Also I have heard of people doing 203 adapted to nv271s also so you get the stronger case but no twin stsick fwd only option...
Some times the cost of maching, adapters, and other parts cases makes it affordable to step up to a Stak 3 speed transfer case or some thing similar..
Since your truck is a 2wd remember they did make divorced 203's and they are rare so a divorced 203 adapted to a 205 or NV271 /273 would be nice. ..The divorced NV273's are in 4x4 Chevy /GMC 4500-5500's they are pass drop too. you can modify the electric shift 273's to manual shift also. I'd seriously look at the divorced transfer case option with your 2WD.
Thanks,
Deo
therabbittree
Postby therabbittree » Tue Mar 15, 2011 7:55 am
another idea is using a auto 23spline transfercase with a 23 spine male 203 and this adapter from Second Hand Smoke http://shop.shsdiesel.com/23-spline-to- ... PLER.htm... might worked out as the auto trucks can do th edoubler alot easier. etc
therabbittree
Return to Competition
