I'll get on to the Automatic Service Info as I titled it now.
I had the FSM for my truck and decided I would attempt a rebuild of the transmission since it was the primary source of my external lubrication system... So I thought I would order the Automotive Transmission Service Group (ATSG) manual since it was about $100 less than Chrysler's publication specifically for the 727's
Here's the heads-up. The same exact info is in the FSM, I was disappointed to find it is nearly a carbon copy with a few exceptions to include a couple pages that are reversed. If you want to rebuild your own and have the FSM, your set. If you don't have the FSM, I would opt for it even though one cost more than the ATSG manual. You will get your moneys worth with the FSM. If your bold enough to try a tranny rebuild and you don't even have a FSM do yourself a favor and get one or other.
My question is this. Does anyone with the newer truck/transmissions (518/618 or 46, 47 RH) have both a FSM and ATSG manuals to confirm the same info can be obtained from the FSM as the ATSG booklet for the later transmissions. I do have the ATSG A500/518/618 booklet if someone has a 92-93 FSM. Maybe PM me your phone number and I'll call you to read off a page or two to confirm. I'm betting it's the same, and in that case I would rather have a later FSM off ebay than the booklet info...
