Clutch Price
Postby CAJUN 93 » Tue Jan 09, 2007 12:24 pm
OEM 13" SACHS PART#4504021 cost $690.00 list $1150.00
6 spd starter spacer part#5018522ab cost $58.05 list$96.75
spacer bolts part#5018174aa cost$9.90ea list$16.50 ea.
just so ya'll know :)
CAJUN 93
Postby KTA » Tue Jan 09, 2007 12:44 pm
Off topic, but Cajun do you work in a dodge parts department?
Postby CAJUN 93 » Tue Jan 09, 2007 3:16 pm
YEP. been back in dodge parts for about a year now. sold em for 5 years back in the 90's, but ended up with gm for a while. also wrote service at a dodge-buick dealer for 2 years. wont be back on that side of the counter again :shock:
CAJUN 93
Postby Fred S » Tue Jan 30, 2007 9:11 pm
whereswaldo, did you get your clutch installed?
92 W250 LB Crewcab 3" Alcans, NV5600 4x4, 35inch Toyo ATs, some tweaks
2001 Golf TDI TDTuning-Stg4, R520s, SBC, 17/22
94 Toyota Ex-Cab 4x4 (01 ALH(TDI)) TDTuning-Stg4, PP764s, SBC, 17/22
Fred S
Postby whereswaldo250 » Wed Jan 31, 2007 6:42 pm
Naw not yet shes still sweaken and sqeelin when the clutch is in but she is still grabbing (for now). I hope it will hold till the summer.
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby cumminsram » Sun Feb 04, 2007 2:48 pm
KTA in your earlier post you said you used a finger clutch cover what does this mean? Also how do you change pleat load. Also after changing pleat load do you have to reinforce the little bar that pushes it in so it wont bend? Thanks, sorry about askin these questions so late in the post but im just now startin to think clutch upgrade.
03 duramax reg cab 4x4 6sp blue, daily driver
93 w350 reg cab 4x4 5sp single wheel
sold: 1993 auto 4x4
SOLD:1990 power ram 250 4x4 5sp
cumminsram
Postby cumminsram » Sun Feb 04, 2007 2:49 pm
sold: 1993 auto 4x4
cumminsram
Postby KTA » Sun Feb 04, 2007 10:48 pm
It means it has 4 fingers instead of the diaphragm style OEM clutch our trucks have. you increase plate load by putting in stiffer/more springs in the cover. I have not done any additional mods to make these work.
Return to Transmission
