splitter
Postby MunK » Sun Aug 24, 2008 6:15 pm
Ezra wrote:Going up Eisenhower in Drive in a class c is a pretty good acomplishment.
LoL It's a rather light weight (12,000lb) 25' with a 514Ci Big Block Ford that I built for bottom end grunt...it's has power to spare...is not bad on fuel for a camper but if you want to go uphill fast...it's a 6 mpg camper. I have been dreaming of a 6bt/Allison conversion...but the crew cab needs finishing first.
91 W250 Nv4500/3.55
85 W350 Crew Cab (soon to be a 6bt/Nv 4500)
MunK
Postby 1991cummins » Mon Jan 19, 2009 11:13 pm
curious, how do you tell it to switch from od to regular drive... just a toggle switch, like maybe a button you could install on your shifter? how quick is the shift?
1991cummins
Postby Ace » Sat Jan 24, 2009 9:28 am
Here's what mine looks like. It could be a button on the dash for an auto:
http://stuff.is-a-geek.net/PhotoAlbum/C ... CTD_93.jpg
Return to Transmission
