HD pilot bearing ??
HD pilot bearing ??
Postby mprmn08 » Wed Feb 18, 2009 9:09 am
I just bought the HD pilot bearing upgrade for my truck and had a question. When you bore the flywheel, do you bore it just deep enough so the bearing sits flush with the front of the flywheel or do you want it recessed in there a little ways? i know you want a step left for it to sit on but how deep? thanks
chris
mprmn08
Postby apwatson50 » Wed Feb 18, 2009 9:10 am
I'm sorry but I can't answer your questions for sure, but I have one for you. Are there any numbers on the bearing its self?
Thanks, Aaron
92 Cummins, 4x4, 270K miles
apwatson50
Postby mprmn08 » Wed Feb 18, 2009 9:15 am
1635RS just the part #
mprmn08
Postby mprmn08 » Thu Feb 19, 2009 5:22 pm
no body has done this? or has everyone just done it when they upgrade there clutch and came bored already?
mprmn08
Postby pulltilbroke » Thu Feb 19, 2009 6:47 pm
I've heard you want to leave about an 1/8 inch shoulder
Postby dpuckett » Thu Feb 19, 2009 7:36 pm
You want a good solid shoulder, not sure how thick- mine is flush with the rear (clutch disc side) of the flywheel. There is 1/16-1/8" on the other side of it.
Dan
Return to Transmission
