Bullet "Resistant" Transmission
Postby gomerpile » Mon Oct 29, 2007 8:28 am
so i am going to be upgrading my tranny here soon and have a few questions,
1st and foremost- i need a TC, i was thinking hughes,
2nd- do i need a shift kit, or is it just for fun
3rd- will i need a tranny cooler
4th- Will this support 350hp
5th- anything else going to be required
6th- stuff to watch out for?
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby Philip » Tue Oct 30, 2007 9:28 am
If your going to upgrade the trans I would recommend a 47RH trans and get away from a fluid coupling trans all together.
1st---Hughes makes good converters.
2nd---A shift kit will speed up shifts. This in turn stops heat buildup. Its a
good idea.
3rd---What are you doing with the truck. Playing or towing? If just
playing the stock coolers will do. If towing heavy add another one.
4th---I would go threw the whole trans. You have to pull it to do a
converter anyway. 350HP on a older high milage trans is asking
for problems somewhere down the road.
5th---see my first statement.
6th---If your not doing the work yourself. Make sure the person knows
Dodge transmissions good. Diesel experence would be better to.
Postby DTanklage » Mon Nov 05, 2007 12:48 pm
hp doesnt hurt a auto trans but torque sure does
how much torque do you plan on having at 350 hp?
that is the number you would want to relay to your tranny guy - that, and application...
from what i hear these first gen trucks make more torque at a given hp level than most of the other combos
don
ps - a shift kit isnt an option at the torque level you are referring to - it is mandatory
jmho
DTanklage
Postby gomerpile » Mon Nov 05, 2007 3:26 pm
I was shooting to have around the 800 lbs of torque range. and why is the shift kit mandontory? i know it stifens up the shifts, but does it do more? of coures the reason i dont want the shift kit is, well this explains my knowledge of a auto tranny :pottytrain: , and what are some of the downsides of a shift kit, I.E.-wearing out componets wise, i mean hitting stuff with a sledgehammer is differnt than hitting them with a rubber mallet.
gomerpile
Postby cummins king » Mon Nov 05, 2007 4:02 pm
your probly going to have more torque than 800 at 350, my budys got 310hp with 875 torque
93 4X4 auto
cummins king
Postby gomerpile » Mon Nov 05, 2007 6:02 pm
well im wanting about 250 motor with 300 w/m, so i said 350 for overkill.
gomerpile
Postby DTanklage » Mon Nov 05, 2007 6:40 pm
it easier on the trans if the line pressure is higher than stock
i wasnt saying to install a manual valve body and jack the pressure to 800 psi (although if it were mine that is what i would do...:))
DTanklage
Return to Transmission
