Putting a Getrag in my 93 Auto? Anyone done it? Pointers?
Postby sxd217 » Fri Oct 05, 2007 8:58 am
I am looking at putting a Getrag from a 91 w350 in my 93 w250 that currently has an automatic in it. Has anyone done it? Any advice?
sxd217
Postby LEADFOOT93 » Sat Oct 06, 2007 10:26 pm
Yeah, I'm planning on puting an nv4500 in my auto, so any help would be much appreciated.
LEADFOOT93
Postby nooblet » Wed Oct 10, 2007 1:29 am
I helped my buddy swap out his tf727 in his '92 CTD to a Getrag. What do you need to know? He bought a wrecked 1st gen with the Getrag and swapped the trans and t-case. I think he had to have a front drive shaft lengthened and the rear shortened. It was not a fun project. If you are going to go to all that trouble I would put a good clutch and a NV4500 in it. He had to get his Getrag rebuilt 5 months after the swap, go figure.
By the time you buy all the parts and do all the work you could have a pretty beefy auto built, just a thought.
Chris
nooblet
Postby Bookshelf » Fri Oct 12, 2007 4:44 am
If you have a donor truck it really shouldn't be too bad. It is much easier to find clean auto 4x4 than 5 speeds and they are always much cheaper too. I'd rather change a transmission and put new pedals, etc in than swap body parts, etc.
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby moab4x4 » Sun Oct 14, 2007 1:54 am
My 92 was auto, the 93 parts truck that I got for the engine was Getrag. I wanted the 5 speed and do not regret the change. (and yes, I have had to rebuild the Getrag, but I still like it. I suspect that if I had opened it up, inspected it and checked preloads I would not have had the issues I did.)
One issue that I ran into other than the driveshafts being different lengths, was that the yoke on the 92 auto truck was smaller than the yoke off the 93 5 speed so when I grabbed the parts truck driveshaft, I had to install a conversion u-joint to fit the auto's front yoke.
Not a trivial swap, but I think it was good for me as I already had the parts truck.
One cool thing you can do if you do this swap is use the tranny fluid cooler for your Power Steering. :)
Ken
92 W350 LE Getrag, 3.54, 4"/2" lift,
HTT Stage II, POD's, 4", PDR cam, KDP, 3200 GSK, Pin ground, Keyed Valet
Pyro, Boost in Message Center, Isspro tach, Damplifier-ed entire cab! Dual Batts, Keyless Entry, LED's in dash
moab4x4
Postby Bookshelf » Sun Oct 14, 2007 7:13 am
I just ran across the front driveshaft difference myself. 93's and some late 92's have bigger yokes and front u joints.
91.0 W250 Auto
90 Chevy V30
Bookshelf
