Getrag durabilty?
Getrag durabilty?
Postby ford69557ci » Mon Oct 29, 2007 12:25 am
How much power can a getrag handle??? Gear size wise it looks heavier than a nv4500. Is it just the small bearings that are weak?
ford69557ci
Postby wannadiesel » Tue Oct 30, 2007 2:55 pm
Mine's holding up OK. I know KTA blew his out, but that was drag racing.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Tue Oct 30, 2007 4:47 pm
wannadiesel wrote:Mine's holding up OK. I know KTA blew his out, but that was drag racing.
Drag racing with what, 800 HP?
Postby dpuckett » Tue Oct 30, 2007 4:55 pm
Bill Gilbert- 450 RWHP.
GLHS- I know has topped 400, but I'm not sure if it's a G360 or NV4500.
It's not what you got, but how you use it. Or in this case, how it is applied. Drag racing will break all but the best and most expensive stuff. Towing and smoking ricers can be done for many miles with no detriment to any of the drivetrain.
Daniel
Postby ford69557ci » Tue Oct 30, 2007 5:12 pm
i plan on hookin to the sled at the local pulls seems like everyone around here thinks and edge easy and an intake is a hot diesel pull truck lol.
ford69557ci
Postby KTA » Wed Oct 31, 2007 6:39 am
I took some teeth off 3rd drag racing at 627rwhp and 1300tq. I never had a problem with it when it was around 500rhwp and 1100tq. It is back together and still in the truck holds fine in normal driving.
Postby ford69557ci » Wed Oct 31, 2007 10:57 am
i wonder if that heavy ass utility box on the back helped that third gear out any??? :jumpsmile:
ford69557ci
Postby KTA » Wed Oct 31, 2007 11:51 am
I am shure pulling the left front wheel on the gear change did. 8)
Postby PToombs » Wed Oct 31, 2007 1:31 pm
I bet it was the nice smooth shift you made into 3rd that did it! :mad:
Postby THE TANK1 » Tue Nov 06, 2007 7:21 pm
I only have about 300hp but I sled pull with a double disc and have not demo'ed it yet. I think 1st and 2nd are tough, I pull in hi range in both.
1990 dodge 550 monkey pump, stacks, southbend DD,
THE TANK1
Postby GLHS » Fri Nov 09, 2007 8:37 pm
Same answer as Brian;
I've never had a problem except shifting very fast into 3rd and that's when the teeth broke.
Still have the Getrag at 455+ hp uncorrected.
GLHS
