Nv5600 flywheels?
Nv5600 flywheels?
Postby josh_6bt » Sat Jun 20, 2015 8:45 pm
My getrag blew up this weekend. Gonna swap a nv5600 in its place. Question is my question has a 550hp SBC. Can I reuse my flywheel and buy a new clutch disc and pressure plate for a 6 speed? If I can't use it will a common rail flywheel work? And lastly what's everyone's thoughts on using a bronze pilot bushing?
1992 W250 EC, 5 speed, 3.54s, 175hp p-pump, timed @ 16.5, #100 fuel plate, 4k GSK, 5x14, .024 DV, head studs, 60lb VS, 4" exhaust, BHAF, cooler tubz.
josh_6bt
Re: Nv5600 flywheels?
Postby txs » Sun Jun 21, 2015 7:51 pm
You should be able to just buy a disc with the 1 3/8" spline to work with your pressure plate. IIRC the early 5600s had an 1 1/4" input shaft so there are a few of them out there.
txs
Postby josh_6bt » Mon Jun 22, 2015 6:03 am
Ok cool. I wasn't sure if could do that or not. Thanks
josh_6bt
Postby PToombs » Mon Jun 22, 2015 5:34 pm
I have an NV5600 flywheel in my truck with my Getrag. They just sent me a disc with the correct spline when I upgraded my clutch to the 650hp ceramic one.
Postby Douglas » Fri Sep 04, 2015 10:56 am
I have the whole NV5600 rig in my 1990. SBC flywheel and a Luk 05-101 OE clutch. You will need the Gen2 starter too since you're going to be running the thicker Gen2 spacer. Mine uses the spacer. I am not making power like Pete so I avoided the huge clutch...:)
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
