Drain plug
Re: Drain plug
Postby Diesel » Fri Jan 25, 2013 5:07 pm
If you don't get this drain plug I have a better solution for you.
Get a boat oil change suction tool. Then you just empty the pan via the dipstick before pulling the pan. You can also replace steering fluid and brake fluid quickly and easily. I even use it to draw my rear down before pulling the cover or an axle shaft.
1991.5 D250 Intercooled A518
Diesel
