BC847 wrote:Lacking that spline alignment tool myself, I learned to assemble the OD section first (using the bare intermediate-shaft), then assemble the 3-speed section, then drop the OD section on the 3-speed section.
ellis93 wrote:Don't you have a broken shaft somewhere?
BC847 wrote:sorry about the hijack.
cmann250 wrote:Do you recall where you got your flex plate?
BC847 wrote:But I did find what I believe is the article http://www.ebay.com/itm/Cummins-6BT-5-9 ... 0807058930
fatty wrote:I put that PRW flexplate in my pickup about a month ago. Drove 40 miles and pulled the trans again to replace the input seal and install the bellhousing spacer.The input seal was totally destroyed from the converter rubbing against it. The pump cover even was starting to wear a little. That spacer cost 90-something bucks shipped so it might be cheaper to get a flexplate that isn't so thick.
