Shift Kit
Shift Kit
Postby CaseyF » Sun Mar 13, 2011 11:30 pm
I was looking at the shift kits on summit racing's website and ran across an all manual shift kit. How exactly do these work? Do you just shift it on the column or set the shift points where you want them?
1992 W350 flat bed. GlowShift Gauges, 3.54 gear, Full Power Screw bottomed, DennyT Pump Top Delete, 366 GSK, Custom CAI, Pro Comp fuel pump, DE 4'' Exhaust, 14cm Exhaust Housing, Getrag.
CaseyF
Re: Shift Kit
Postby dazedandconfused » Mon Mar 14, 2011 6:23 am
Manual VB is exactly that. You install that kit you shift every gear. If you do that I recommend a floor shifter.
Re: Shift Kit
Postby ellis93 » Mon Mar 14, 2011 6:34 am
X2 on the floor shifter. There's nothing like getting into reverse at 50 :lol:
Re: Shift Kit
Postby dazedandconfused » Mon Mar 14, 2011 8:08 am
I personally like the ratcheting shifters and a reverse pattern manual VB.
Re: Shift Kit
Postby CaseyF » Mon Mar 14, 2011 1:18 pm
CaseyF
Re: Shift Kit
Postby dazedandconfused » Mon Mar 14, 2011 3:29 pm
Some people like them and some don't. I think they are fun myself in all the gassers I've drove with them.
Re: Shift Kit
Postby CaseyF » Mon Mar 14, 2011 7:22 pm
I've always wanted to swap a 5 speed in, so this would be the closest thing until then.
CaseyF
Re: Shift Kit
Postby jughead » Wed Mar 16, 2011 9:43 am
this old man is still looking for a reverse pattern manual valve body for a 518 that is somewhat cheaper than 900 bucks. would even take a shift kit they are not that hard to install. any and all help appreciated.
jughead
Re: Shift Kit
Postby delinquent » Wed Mar 16, 2011 1:58 pm
wouldn't the 727 valve body be made to work???
delinquent
Re: Shift Kit
Postby jughead » Wed Mar 16, 2011 3:20 pm
really dont know i can do the 727 not a problem. if worse comes to worse i will do the lower part just like the 727 and try it. od is electric anyway. i will probably put the stock one in and make sure it works ok then modify the 3 speed part and see if it works. i have a shop so i can try it on a lift. i would pay 500 for the 518 but 900 to this old man is uncalled for.
jughead
Re: Shift Kit
Postby dazedandconfused » Thu Mar 17, 2011 3:28 pm
jughead wrote:this old man is still looking for a reverse pattern manual valve body for a 518 that is somewhat cheaper than 900 bucks. would even take a shift kit they are not that hard to install. any and all help appreciated.
Just got my A&A transmission catalog and it has reverse pattern manual vb for the 518 listed. Says please call and has $600 listed with $100-200 core.
Re: Shift Kit
Postby CaseyF » Thu Mar 17, 2011 7:10 pm
CaseyF
Re: Shift Kit
Postby jughead » Fri Mar 18, 2011 3:30 am
couldnt find it listed in A and A catalog online guess i will give them a call.
jughead
Re: Shift Kit
Postby dazedandconfused » Fri Mar 18, 2011 4:31 am
Call Pat at 317-831-3066. That is what they emailed me back.
Re: Shift Kit
Postby jughead » Fri Mar 18, 2011 4:49 pm
thanks guess i will order next week if nothing goes wrong. still a little high but when u play u pay
jughead
