one piece aluminium driveshaft
Postby dieselcountry85 » Wed Jan 30, 2013 12:34 am
I had one on my 05 and liked it but after getting under my 92 not sure of clearances and angle? Anyone have one on their getrag?
dieselcountry85
Re: one piece aluminium driveshaft
Postby dieselcountry85 » Thu Jan 31, 2013 11:15 am
No takers?
dieselcountry85
Postby ellis93 » Thu Jan 31, 2013 11:22 am
All I've ever seen was steel under these trucks
Postby cmann250 » Thu Jan 31, 2013 11:26 am
I developed a distaste for aluminum driveshafts after I watched about half a dozen "street stock" Duramaxes twist them off in one night of pulling.
Are you refering to the one piece nature of the aluminum shafts?
Postby CumminsPower59 » Thu Jan 31, 2013 11:49 am
I don't see why you couldn't use one, as all I have ever seen are the ones that have t-case rear slip outputs instead of fixed yokes. Our trucks run fixed rear outputs, so unless you want to convert to that somehow, running the stock steel driveshaft is going to be your best bet ;)
Postby dieselcountry85 » Thu Jan 31, 2013 12:08 pm
I have had carrier bearing issues before and like to do away with the problem before it becomes one. But, the aluminum one piece on my 05 was a 5 inch tube and it looks like my exhaust and fuel tank wouldn't like that much metal swinging around between.
dieselcountry85
Postby CumminsPower59 » Thu Jan 31, 2013 12:18 pm
Not much you can do about that, it's incredibly hard to balance a really long driveshaft if you want to do away with the carrier bearing...some shops might not even make one that long for liablity reasons, as most shops have the "stock is best" mentality :roll:
Return to Transmission
