What fluid are you guys running in your auto trans? My dipstick says DexronII but that is not available. Have been using ATF+4,is this necessary? What is best for towing and longevity?
Thanks.
Eric
Tacoclaw wrote:Correct me if I'm wrong, but doesn't each higher number of Dextron supersede the last?
As in you could run Dex 2-5 in our trucks but not Dex1?
Also, like dunes said, I thought Mopars used +4? Don't Fords run the Dex/Merc?
93 W350 LE wrote:I've been reading some of you are just running hydrolic fluid, and the higher viscosity is supposed to help "tighten" it up a little bit. Any thing bad associated with this?
