Best Clutch
Best Clutch
Postby Underpsi » Wed Nov 14, 2007 8:23 pm
Whats the best clutch to use for the street maybe a bit of drag and only a toy not daily driver? Will a DD work with the getrag cuz don't you need to upgrade the input shaft or something? Will the best single hold up to third gear launches?
1989 D250 5spd w/SB3250DD, .020 over head gasket, O-rings, Extensive port/polish, ARP head studs, 62/71/14, 6x.018 sticks. First Dyno stock turbo and pods: 343/879
2nd with 62 & big sticks: 393/813
Underpsi
Postby Underpsi » Sun Nov 18, 2007 11:51 am
Bump.... Nobody.....
Underpsi
Postby cummins king » Sun Nov 18, 2007 12:37 pm
you just need a heavy dudty single cltch, if you wait till its fully ingaged like in the rase cars then you shouldn't ever have a problem, its when its not ingaged and you steped on it that it makes it slip, you should get a southbend clutch it will be good
hey what you bin up to you guys haulin lots this week
93 4X4 auto
cummins king
Postby PToombs » Sun Nov 18, 2007 4:15 pm
Call Peter at South Bend Clutch. Tell him what you have and what you are doing, he'll tell you what you need. His clutches are expensive, but you are paying for knowledge and customer service that is beyond compare.
:wrench:
Postby Underpsi » Wed Nov 21, 2007 9:11 pm
ended up buying a 3250 DD from southbend, got a killer deal so I had to take it
Underpsi
Postby KTA » Thu Nov 22, 2007 11:17 am
You shouldn't have any problems getting that to hold. Getting it to fit might be though. Be shure its made for the right sized input shaft.
Postby Underpsi » Thu Nov 22, 2007 1:59 pm
Yeah thats why i figured I might as well get it. Should last me pretty well forever. It should fit no prob, Its getting the proper 1 1/4 plates in it next week
Underpsi
Postby ford69557ci » Thu Nov 22, 2007 6:43 pm
i had the local clutch shop build me a dual disk its rally meant for pullin. the only bad drivabilty part is that at low rpm its either in or out there is no inbetween. but there is absolutely no slipping when on the go pedal like my old single disk.
ford69557ci
