help me select a proper clutch
Postby rockmike » Wed Dec 11, 2013 10:29 am
Hey guys, I could use some advice.I have a 93 2wd getrag dually:hx35, bosch 190's, BD high performance inj pump, WM,4" exhaust,2nd gen high volume lift pump,dynamic timing spacer,3200 rpm spring.
I tow about 18k with her often,no racing,no pullin,just a driver and a hauler.
I installed a quality(AMS) OE type clutch a couple years ago and its slipping pretty bad and bucks like crazy trying to back up.
What would you recommend I replace this one with?I aint got money spraying out my rear,but I aint broke ass either lol just want to spend the right amount and have a clutch I can rely on for long while.I have to back my trailer into some tricky spots often,this buckin sthi in reverse has got to go!
lets discuss and thanks!
Mike.
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Re: help me select a proper clutch
Postby CumminsPower59 » Wed Dec 11, 2013 12:41 pm
I have a Southbend 13" with 3" organic facings. I don't tow with it, but Ellis has the same clutch and he tows a bit with his...hopefully he'll chime in...
Postby ellis93 » Wed Dec 11, 2013 1:09 pm
CumminsPower59 wrote:I have a Southbend 13" with 3" organic facings. I don't tow with it, but Ellis has the same clutch and he tows a bit with his...hopefully he'll chime in...
Yep.....kick a$$ clutch for the money,no herky jerk in reverse while pushing a load.....priceless stock peddle feel with absolutely no grabby feel trying to take off.
If your gonna tow,stay with organic faces......wide faces. BTDT on a ceramic....gets real old,real fast :cry:
Contact the Hungry Diesel.....tell'em you want the poor folks pricing, Eric is a good dude to trade with ;)
Postby rockmike » Wed Dec 11, 2013 2:21 pm
Eric is an awesome guy,thats who I bought my lift pump from.
Sure appreciate the help and info guys...keep it coming.
rockmike
Postby rockmike » Wed Dec 11, 2013 2:28 pm
BTDT?
rockmike
Postby BILTIT » Wed Dec 11, 2013 2:39 pm
BTDT= Been there Done that.
I would possibly even recommend the valair dual disc organic, depending on how you drive/tow.
Derek B.
BILTIT
Postby rockmike » Thu Dec 12, 2013 4:26 pm
Thanks again guys.I talked to Eric @ hungry diesel and he gave me some great info and yes I think what you guys suggested is going to be an ideal clutch for me also.Got a save some $$ and I'll order one through hungry diesel, he not only deserves our support but hes earned it!IMHO.
Mike
rockmike
Postby CumminsPower59 » Thu Dec 12, 2013 9:32 pm
Eric does a bang up job. I've always had pleasant results with my dealings with him.
Postby ellis93 » Fri Dec 13, 2013 4:24 am
Yep.....another back patter here :)
You should search for governor spring and effects of timing in the sites crappy search,read the arguments I've had with him :shock: Treated me right....even after all that :lol: He's a trooper :thumleft:
Postby rockmike » Mon Apr 14, 2014 2:19 pm
Ive got some miles on that clutch,about 2500 miles on it now.I like it! it shifts great a lil grabby compared to my OE type clutch,no bucking when backing up the big trailer.
I too will recommend this clutch for our work trucks 8)
rockmike
Postby jdiesel_us » Sun May 04, 2014 1:08 pm
Wow that is good to hear I just bought a 91 2wd dually that has the exact same symptoms while trying to back a trailer. I had a real hard time finding anything but stock clutch listings for a 1st gen.
jdiesel_us
