Difference in drive shafts between the 3 and 4 speeds?
Postby Begle1 » Mon Nov 19, 2007 4:11 pm
My new 4 speed's on its way.
I should get away with just a front driveshaft and yoke out of a 93, correct? Anything else?
Postby Cschafer » Fri Nov 23, 2007 8:20 am
I am pretty sure the driveshafts are the same in 727 and getreg trucks but I know the 518 is longer so I think you will need both shafts out of a 518 truck.
91 w250 wrecker
Cschafer
Postby Begle1 » Fri Nov 23, 2007 9:17 am
Why would I need both?
Isn't the carrier bearing/ rear drive shaft assembly the same for all years?
Users browsing this forum: No registered users and 86 guests
