are all 727 long tail shafts the same?
Postby Joecochrane » Fri Feb 07, 2014 11:41 am
I removed the gearvendors off my 727. Now I need to replace the adapter with a tailshaft housing. My question is will any long tail shaft housing work ore were the diesels different.
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Re: are all 727 long tail shafts the same?
Postby txs » Sat Feb 08, 2014 6:33 pm
all the 727s ive ever seen behind a diesel were the shorty extension with the bolt on yoke.
txs
Postby Joecochrane » Sat Feb 08, 2014 8:29 pm
Oh well that leaves me a lil confused.
Joecochrane
Postby txs » Sun Feb 09, 2014 3:08 pm
If you have the long output shaft with the slip yoke spline any gasser 727 truck long extension will work.
txs
